HELP! Active Body Control Drive carefully on
Local dealership can't touch it until Wednesday so I topped the reservoir up (almost 1 litre) on the basis that ifit drains itself, I can't move the car to the dealers shop.
Also tried the raise / lower switch on instrument panel but nothing happening there ither before or after topping up level.
BTW Oxygen...didn't need the Vaseline, plenty of oil on my hands......may need it next week I guess.
Current stable:
Bentley Continental R Le Mans
Bentley Arnage Diamond Series
Bentley Turbo RT long wheelbase saloon.
Bentley S3 saloon ( x2)
Here, scroll down until you see the high pressure expansion hose and it will show you how they fail:
https://mbworld.org/forums/cl55-amg-...-pictures.html
If the hose was leaking, it would be visible first.
Oxygen?
I always wanted to raid the W220 parts section in the main Mercedes parts warehouse and have a large box truck outside ready for loading.
I guess you can have them check the A/C system for you and possibly add more freon.
Have them check out all the ABC lines, check out all the grommets and mounting brackets to make sure nothing is rubbing or leaking oil. Also check the hydraulic connections going to the struts, I've seen them leak at the connection.
I circled in red all the ball joints and bushings that you should replace if you are taking that route. Instead of doing just one ball joint I would replace all of the bushings and ball joints and restore the brand new feeling in the suspension and steering.
You're a mine of information and I thank you for sharing.
Two days ago, I overshot a turning and reversed the rear end onto some uneven ground while the front wheels stayed on tarmac road surface. There was a sudden graunching noise like tyre rubbing on body and immediately as I drove forward the ABC warning light came up.
I stopped the car and applied some body weight to the rear end (hopefully) and guess what...the light extinguished and the car drove fine . The next day I started up and drove 100 miles before taking a break....when I restarted, the ABC warning light came back on. Once again some weight to the rear end and presto...back to normal. I set the body height up to max and then back to minimum and selected sport on the ABC and drove another 100 miles. When I came to start again, same old light....so I applied the same old body weight to the rear end and got the same old result....problem sorted.
It seems that each time I turn the engine off, the ABC warning light comes up....what's going on here?
When I tried using some aftermarket wheels (ET30) with my 05 CL55 (ET4X) - I had rubbing problems and ABC problems.
I would find out exactly what AMG or Brabus wheels have the recommended offset for your particular model. Look in your owner's manual or on the door. MB also has a comprehensive wheel catalog that covers just about every year with full specs. You can probably get it from your sales or parts department.
BTW, the manufacturer of the aftermarket wheels "guaranteed" they would work with the CL55. They didn't and the independent dealer took them back with no issue. They would work on a CL500 though. I spoke to the manufacturer's rep on the phone - he said "so what's the difference? They are the same models, just a bigger engine."
Often wrong, never in doubt!
