Car drops on one side while driving
What could it be?
It is a very complex system. They may replace that side pump and then find out the filters are clogged. Are there any fluid leaks in your garage? The fluid maybe down. I could go on ad nauseum.
The system needs regular service such as a filter flush - there are many discussion here on the Forum.
For a quick driveable fix raise the car so both ABC lights are on. The responsibility is yours - just a tip.
Can I replace the accelerometer sensors myself? Can this be a DIY? Where are they located?
Since this was a warranty recall however, you should be able to have your dealer check to see if your sensors are part of the effect group and is so, work will be done free.
The car is at the dealer for alot of work and things that need to be fixed and I addressed them about this issue as well. I hope it will be a simple fix. Will update once I find out what is the cause, hope fully like others mentioned the accelerometers is the culprit..
