CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
No power off the line in tt v12?
Old Aug 20, 2009 | 06:39 AM
2003 S600's Avatar
2003 s600
I just got my car back from body shop and I floor it from a stop and it upshifts, does not spin wheels and no power off the line. What could be the problem? They replaced all radiators, oil cooler, heat exch, ac condenser, rad fan. Tranny fluid level ok. All vacuum hoses look ok. This has kleemann ecu/tcu so it normally lights up tires even with esp on.????????
Old Aug 22, 2009 | 03:49 PM
Viet_Amg408's Avatar
Pinto
any warning lights on?
Old Aug 25, 2009 | 01:21 AM
2003 S600's Avatar
2003 s600
none.
Old Aug 27, 2009 | 05:14 AM
2003 S600's Avatar
2003 s600
Had dealer run codes and diagnose, boost and tranny codes came up: P2001 Charge pressure too low and P2318 One or more messages from control unit N15/5 (Electronic selector lever module control unit) are not available on the CAN bus. (CAN timeout fault) ---both current and stored. Anyone know what I need to do?
Old Aug 27, 2009 | 10:26 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
What did the dealer tell you they wanted to do?
Old Aug 27, 2009 | 08:46 PM
blahuh's Avatar
1998 C43
have the dealer fix it and make body shop pay. Boost pressure to low could be caused by lots of things. How much work was done at body shop?
Old Aug 28, 2009 | 04:27 PM
alx's Avatar
alx
you leak boost from somewhere.
have shop recheck their work - especially around hoses, turbo outlets, intercoolers.
alex
few cars
Old Aug 30, 2009 | 02:39 AM
2003 S600's Avatar
2003 s600
i fixed the boost problem myself today. it was the dam wastegate rod, the nut at the end was gone. the wastegate was stuck open, nothing to pull the door shut. what about the trany code. did they pour a can of soda over my shifter module?
