Anyone check how much boost you make. Just got the dashdaq and it shows 35 psi. Anyone know how to adjust that to actual boost instead of map psi which is atm press + boost? IAT fluctuates a lot. At idle it can go to 170F. If you hit the gas it drops 20-30F due to the volume of air flowing. Cruising at 70mph with outside temps at 70*F it is around 120*F. Throttle angle has a lot to do with IATs. Timing retards a lot if you floor it, can go to 0*TDC, but when decelerating it is -30TDC, normal?
Currently Active Users (1)
