drag racing the cl65 this friday. any tips?
drag racing the 05 cl65 this friday the 4th. i come from a long list of racing corvettes and camaros, but racing this car is something new to me and i want to know what i can do to get the most out of this car.
the car may have an ecu tune on it as i have hit 160-170 on 3 ocassions.
i did purchase some drag radials also: mt 245/40/18 going on 07 s550 wheels 18x8.5.
91/100 octane mix?
launch?
mode?
weight delete?
91/100 octane mix?
launch?
mode?
weight delete?
U seem to have the most important thing covered which is the MT's, warm them up pretty good, and they should stick like glue.
I like to drop them to 18psi, also raise your suspension to highest setting for weight transfer to rear. You could also brake boost at the line around 1200-1500 rpm it the front doesn't move. Always run on dyno mode- its a must.
Almost forgot..bring a lot of ICE!! Ice her down every run, take engine covers off and drop bags everywhere in engine compartment, cover turbos so water doesn't get thru with a cloth or something, I have heard some stories. Let her rip and hold on tight!!
Have fun and post up your results.
CL500 and ML55
I would not use any fuel other than what is recommended by MB!
You do not want to risk detonation and burn a piston or possibly worse...
I am pretty sure the car was probably tuned to run no-lead premium fuel that can be had at any service station. If it was not....then it would not run as well as it does now.
CL65
slk 230 kompressor
hey guys im new here and y was wondering... i have an slk 230 from 96 1 of the first ever made. is a great car but the power is... well is not that powerful so i was wondering if i could mount the 6 l v12 on my slk(secon hand)
slk 230 kompressor
or to tune up the exisstent 4cyl engine up to 300 bhp to drop the acceleration under 5 sec from 0 to 60 can you give me a clue??? or how can??
