CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Anyone fitted 305 on the rear 9 1/2?
Old Dec 8, 2009 | 08:01 AM
TRAKCAR's Avatar
S550 coupe
I drove the car 10K miles in the last 7 months and now my rears are slicks.
Not bad, I expected worse, I think I am showing some self constraint here!
275/35/19 is clearly not wide enough, how wide can I go on the 9 1/2" rear wheel without it looking funny or touching the fender?
I have some Michelin PS2's that I was going to put on my GT3, would 305/35/19 fit?
Old Dec 8, 2009 | 08:33 AM
just slk 230's Avatar
slk 230 kompressor
hy! im new here and iv been trying to find some info! i have an 96 slk 230(great 4 cyl car) but i want more power more acceleration an iv been told that ecu tuning or addon performance parts can damage the engine couse is 4 cyl european car(even wors is mercedes) can you help me???
Old Dec 8, 2009 | 12:51 PM
bisyiafds's Avatar
dsfd
Old Dec 8, 2009 | 02:14 PM
Patentmat's Avatar
If they will fit, I doubt they would fit on those wheels. My 305s are on 10.5 inch rims and that is about the limit, 9.5 inch rear wheel I just don't think it would safely work all that well. I also think the 65 may not support as a wide a tire as a 305, due to its offset being 60mm while CL55 is 46mm. That is, the same wheels on a 55 could stick out on a 65. I was someday hoping to upgrade to a 65 and keep my wheels but I don't think they will work.
Old Dec 8, 2009 | 03:21 PM
Bumstead's Avatar
vw/Audi
Any brand of 305 tire I know of requires a minimum of a 10.5" wide wheel. You could probably get it on the 9.5 wheel but it would wear out quickly in the middle, and perform very "weird" because the tread contact patch would be very distorted. Tire specs are NOT a minor issue......they are very important to your ride and handling.
