CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
could not dyno cl65 today
Old Jan 7, 2010 | 03:51 PM
02cl55amg's Avatar
CL65
could not find a tach lead for rpm pick up. any tips? want to get this thing dynoed before modding
Old Jan 7, 2010 | 05:54 PM
Thericker's Avatar
V12-Biturbo
Forget the hassle unless you use a Dynodynamics or Mustang-dyno you'll have to remove the airboxes to access a lead...Just use good ole DynoJet & get base rwhp the rwtq can be assumed healthy if your rwhp is 500+ on any DJ
Old Jan 8, 2010 | 04:20 AM
02cl55amg's Avatar
CL65
was on a dynojet. i'll try another shop tommorow
Old Jan 9, 2010 | 09:14 AM
blazeone's Avatar
2010 E350
With a small pick up you can get rpm from the fuel injector wire. The first injector on the right bank looking from the front of the car is seating out in the open.
Old Jan 9, 2010 | 02:29 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
The shop should have an optical pick-up they could use. You don't need a tach signal to get the RWHP but you will need it to have RWTQ on the graph. You could always look at your tach and speedometer when doing the run to plot your own torque graph.
HP = (torque X RPM)/5252
Tq = (5252 X HP)/RPM
