Turn the wheel then BOOM. ABC fluid flushed out... HELP! PICS
The struts are FINE and are not leaking but the passenger side top rubber boot is ripped but can be replaced. The pump did run dry for a bit but it holds pressure and is working FINE as tested. The steering rack formed a little crack on top (where it was pissing out fluid from) so I got a refurbished rack installed, flushed the steering fluid and all is well. All under $1000. Did the work myself due to warranty not co-operating.
