CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
2001 CL55 - driver side rear window does not roll down
Old Feb 19, 2010 | 12:43 AM
CL55_Serge's Avatar
CL65 AMG , white S550 Sport w/ white Giovanna 22s, wild custom chopper
Are the rear windows individually fused? Where is the fuse location? The motor worked a week ago, suddenly stopped. I guess it can also be the switch or a window control module of some sort? all other windows work correctly.
Old Mar 18, 2010 | 01:58 AM
CL55_Serge's Avatar
this was an easy fix by the way - took off the rear side panel, opened up the motor, cleaned/greased it and lubricated the regulator. manually moved the windows using the gear when motor is taken apart a few times to check for smooth operation and all works well!
Old Mar 18, 2010 | 09:47 AM
benz_addict's Avatar
V12TT
Glad to hear everything worked out! Thanks for the update!
Old Mar 18, 2010 | 10:48 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
They get kinda jammed!!! i know it sound wierd but on the 220 s class and the 215 cl the window motors jam up just like you said if you remove them and disconect them from power and reinstall they start working again.. see it all the time
Old Apr 7, 2010 | 07:47 PM
deycallmebruce's Avatar
2001 CL 55
wow..i have the same problem on my '01 CL55 that i just picked up!! hope that this is the fix!! will keep yall posted. loving da ride right now....
