CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Lowering button
Rating: Thread Rating: 4 votes, 5.00 average.
Old Sep 5, 2010 | 02:27 PM
CL55AMGRON's Avatar
2005 CL 55 AMG
Lowering button
Hi guys and ladies I have a 2005 cl55 amg Question:the lowering button Do you use it much? What does it do? Will it mess with the abc system? The reason I ask is that I read alot about the abc system problems and I am a little gun shy using all the bells and whistles. Like abc sport,manual shift, and lowering.The car runs like a top and I put alot of miles on it. I am keeping the maintenance up. Should I just stop babying it and have at it.The car is a beast. Sorry for the rambling.... Happy Labor Day
Old Sep 5, 2010 | 07:30 PM
lkirchner's Avatar
Several MB's Superperformance MK III Cobra
Stop babying it and drive it like you stole it!!!!
Old Sep 6, 2010 | 02:55 PM
saintz's Avatar
GL450
Which lowering button? The ABC Sport button doesn't actually lower it. There is a raise button. That should only be used for speed bumps, etc. You want to generally drive it in low mode (both LEDs off).
Old Sep 6, 2010 | 03:28 PM
CL55AMGRON's Avatar
2005 CL 55 AMG
DUH!!!!
Duh do I feel like a . The arrow is pointing up....I need reading glasses bad. So my new question is How does the raising button work? More pressure to the hydrolics? How high does it raise the car? I feels like I live in the speed bump capital of the world. Also I have been driving in sports mode . As you can tell I just took the keys to the car and didn't read the books...Just drove and loving ever minute of it. Thanks for clearing that up.
Old Sep 7, 2010 | 08:11 PM
Q-Dog's Avatar
The button with the arrow pointing up is to disable the towing prevention. I think a siren goes off if the car gets lifted on either end if one does not disable. The normal position is enabled....
Old Sep 8, 2010 | 07:01 AM
saintz's Avatar
GL450
That's actually a different button.
On ABC equipped cars you can raise the ride height (normal height, raised one level, raised two levels). It increases pressure to the strut to raise the car. If you always bottom out on a bump, raise it before going over. Generally, you shouldn't need to do this. It only raises it maybe an inch or so. You can try it and see.
Old Sep 9, 2010 | 08:22 AM
CL55AMGRON's Avatar
2005 CL 55 AMG
Thanks I will be breaking out my ruler and let you know how high the hight goes. I can use it because we have high speed bumps here, My car will scrape if you don,t stop and inch your way over,My son has a honda civic and his car scrapes going over these montains.Happy motoring
Old Sep 9, 2010 | 08:40 PM
lkirchner's Avatar
I use mine at least twice a day on my SL55 when I leave or enter my drive way. If I don't, I will scrape the bottom.
Old Sep 10, 2010 | 01:22 AM
saintz's Avatar
GL450
Yeah, driveways are a good example. That's truly a matter of ride height.
Speed bumps are potentially different. If you have to raise the car to clear the speed bump, period, regardless of speed, that's one thing. But if you're raising the car so you can take the bump at a higher speed without bottoming out, be aware that you may be abusing the crap out of your expensive hydraulic suspension. Those sudden jolts from big bumps can spike the already insane pressures on the lines/struts/valve blocks.
Old Sep 26, 2010 | 11:56 PM
Viet_Amg408's Avatar
Pinto
i use the raise up at least 10times a day otherwise i won't make up over any drive way or speedbumps....because i like to roll around town very low like a gansta..because im gansta you know.. lol jk..
Old Sep 27, 2010 | 12:01 PM
Patentmat's Avatar
I use mine about 10 times a day as well, as my car is lowered. Pulling into my own house every time, any large speed-bumps I cross over, and my office has a nice gutter to go over as well. After 93,000 miles and 6 years, my suspension finally went for about $4500. This seams typical for the life of the suspension and I don't think my usage of the raise feature had anything to do with it.
Old Sep 27, 2010 | 07:28 PM
Pinto
yup that sound about right..
Old Sep 28, 2010 | 12:35 PM
CL55AMGRON's Avatar
2005 CL 55 AMG
Thanks guys I fell better about using the button know. I have 65000 on the car and have my fingers crossed with the abc system.This is my fair weather car and I will have to save up for repairs. But for now all is well.Keeping a close eye on my fuilds.
Old Sep 28, 2010 | 02:48 PM
SLCL's Avatar
CL55, SL500, E350
I think raising the car puts more pressure on the ABC system related parts. The fluid goes into it to raise the car up and keep it there will certainly put more pressure.
Old Oct 2, 2010 | 12:39 AM
CharlestonN's Avatar
03' CL55 AMG
Lamborghinis have a ride height adjustment system too but i believe it only lifts the nose of the car for dips and driveways, i wonder if they are as problematic as the ABC system Mercedes uses
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
