CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
What is the best way to make 05 cl55 amg exhaust louder
Old Oct 17, 2010 | 11:03 PM
palicl55's Avatar
2008 CL63 AMG 2003 cl55 amg SOLD
i already removed the resenaters
Old Oct 17, 2010 | 11:29 PM
Patentmat's Avatar
For anyone who has not done this, +1. It keeps the same sounds, just makes them all a little louder. And I passed California smog. Sorry palicl55, that's as far as I wanted to take it.
Old Oct 20, 2010 | 11:54 PM
CharlestonN's Avatar
03' CL55 AMG
Does deleting the resonator effect performance at all?
Someone told me that it nerfs your torque . . .
How much does a resonator delete cost?
Old Oct 21, 2010 | 12:15 AM
moparrbust's Avatar
2005 Crossfire SRT-6
electric cutouts are the best bang for your buck.........at the push of a button you can go from super quiet to insanely loud(and anywhere inbetween).
Old Oct 21, 2010 | 12:18 PM
palicl55's Avatar
electric cutouts? i've never heard of that before. how do you do that
Old Oct 21, 2010 | 12:31 PM
Patentmat's Avatar
Had a local muffler shop just cut them out and replace them with a straight tube. The parts were HEAVY - - I'm probably saving 15+ pounds on weight. I think it was like one hundred bucks or something. I didn't notice any difference on torque, but then again again if it did make a change it probably would have been too slight to notice anyway. FYI, they may not have an aluminum pipe to replace the gap with. That's OK, at least it has been OK in my case for the last 3+ years since I did it.
Old Oct 21, 2010 | 04:05 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
slap on some magnaflow flow mufflers and reuse stock AMG tips and you will be please with the sound
Old Oct 22, 2010 | 12:12 PM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
The eisenmann race exhaust will wake it back up. A cut out I think would be obnoxious on this engine, way too loud.
Old Nov 3, 2010 | 02:42 AM
lionking30's Avatar
2003 CL, 2008 SL 500, 2007 BMW, 2005 Prius
here is what mine sounds like, actually sounds much much better in person...
http://www.youtube.com/watch?v=lmkSl4O2uFg
Old Nov 3, 2010 | 10:15 PM
sakodik's Avatar
E-Class
I deleted my mufflers. It got too loud and I had to put on magnaflow to soften the rumble. Unless you want to be quiet for your neighbors, deleting both mufflers worked really well for me. goodluck
Old Nov 4, 2010 | 10:17 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Headers and race cats! Get power and sound,,, not just poser sound.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Nov 5, 2010 | 09:19 AM
Mercedes22's Avatar
S500 LWB ( W221 ) - CL63 Biturbo ( W216 ) CL 55 Kompressor ( W215 Sold ) C43 AMG ( W202 Sold )
Are the AMG tips spot welded and how easy are they to remove ? As mine need re-chroming.
Old Nov 5, 2010 | 09:57 AM
PLATINUM SPONSOR
2003 CL55
They are stainless and not Chrome..
__________________
www.ultimatepd.com
Old Nov 8, 2010 | 05:49 AM
Mercedes22's Avatar
Thanks. I didn't know that, which is a shame as to get them shiny you have to replace the exhaust
Old Nov 8, 2010 | 10:39 AM
PLATINUM SPONSOR
2003 CL55
No, you can just polish them out with a small buffer.. Very easy and they will look brand new!
__________________
www.ultimatepd.com
Old Nov 9, 2010 | 08:27 AM
Mercedes22's Avatar
Yes i have tried with my small buffer, no joy I'm afraid. Many thanks.
Old Jan 10, 2012 | 07:29 PM
03' CL55 AMG
Resonator delete on a supercharged engine will not hurt performance, i actually gained 3 hp and a little bit of high end torque after doing mine and the sound is perfect, not too loud and not too soft and still sounds the same as stock just about 30% louder
Old Jan 13, 2012 | 03:30 PM
PLATINUM SPONSOR
2003 CL55
Install the custom headers that I had made and you will get more power, louder and really help your engine get the heat out.. All the other stuff, does not add power and can alter the sound to DRONE mode! IMO
__________________
www.ultimatepd.com
Old Jan 13, 2012 | 07:32 PM
Vabene7's Avatar
Garage Temporarily Empty
Keep in mind your car will be SIGNIFICANTLY louder if you run open electric cutouts on a N/A engine. I ran it on my V12TT only because the turbos quiet the exhaust greatly.
Here is a link to the photo of what I did with my S600.
https://mbworld.org/forums/s-class-w...t-cutouts.html
They work wonderfully. My S600 has it's stock quiet exhaust when they're closed, or a deadly rumble when they're open, or anywhere in between.
Hope it helps....
-Chris
Old Jan 13, 2012 | 08:31 PM
danlnyc's Avatar
04 CL55 (sold), 2012 CLS550 (sold), 2014 S550 (sold), 2015 ES300H (DAILY)
I deleted my resonators only, and in the beginning I thought it was such an improvement however, my friend bought a Porsche 4S recently and when he revved his stock exhausts, mine sounded sooooo quiet I couldn't believe it....
Old Jan 22, 2012 | 07:05 PM
RobsCountach's Avatar
1999 SL500 Sport
Remember, there's a difference between mufflers (under the car) and Resonators after the axle.
Removing the muffler is a good idea (it will reduce low-end torque, but you'll never know it).
Removing the resonator is NOT. It can cause hi-way, overdrive drone...hence why its called a 'resonator'. All sound resonates.
I'm looking for an early 2000 CL55 and will prolly do muffler delete; However, not seeing any viable Intake mod. K&N panels are useless HP. Do for convenience, but that's it.
