CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
need help with my break upgrade
Old Mar 21, 2011 | 03:39 PM
G MoNeY818's Avatar
CL W215
ok I have a 00 cl500 and am installing 04 cl55 AMG calipers on it
the front just bolted right on but am having problem with the rear
I want to know if someone out there has done this same upgrade and what do
I need to change on the rear to make this work
I was told that the hub needs to be changed but just want to know before I
do Please if someone can help me out thanks!
Old Mar 21, 2011 | 04:35 PM
BABYBENZZZ's Avatar
BENZ w203
rear hub needs to be changed
Old Mar 21, 2011 | 05:26 PM
sknight's Avatar
c200k
Breaks suck.
Old Mar 21, 2011 | 06:25 PM
danlnyc's Avatar
04 CL55 (sold), 2012 CLS550 (sold), 2014 S550 (sold), 2015 ES300H (DAILY)
so you bought yourself expensive "brakes" without even knowing if they would fit or not? -_____-;;
Old Mar 21, 2011 | 08:21 PM
elijah's Avatar
Euro Cars Only
Give the newbie a break and help him out. No need to throw BS at his face.
Btw welcome to the forum. If i could help i would but I dont know much abt your car. Use the search function its your friend you might be able to find some answers.
Old Mar 23, 2011 | 09:29 AM
momentum59's Avatar
'00 RENNtech CL60, '96 850Ci, '92 850i '01 Discovery II
i have done this conversion, you will need to have a bit of custom work done. the front hub mounting will need to be bored our to accommodate the larger bolts, i have yet to mount the rear hubs as the current hub will need to be machined and not bored. The system is amazing, i replaced my RENNtech F40 system and i can say these are better in many way. And just so we are on the same page, you have the 8 piston 4 pad fronts and 4 piston rears?
Old Mar 23, 2011 | 09:33 AM
momentum59's Avatar
i just reread your post, i guess you got lucky on the front with them fitting fine on the front, please be careful as the front feels like it bolts up fine and reality the bolts are not correct if you are using the OEM ones from your original setup. I had to buy the the correct bolts from the dealer and after they didnt fit in my OEM hub. just an fyi. But do post up pictures!
Old Mar 23, 2011 | 12:39 PM
G MoNeY818's Avatar
CL W215
yes I used oem cl55 bolts and had to do some work on the knuckle to make to bigger bolts go threw but as for the back I just ordered the rear hub for cl55 will update as soon as I can
Thanks for all the help !
Old Mar 24, 2011 | 07:31 AM
momentum59's Avatar
by the way i found someone else who did this conversion today on the forums and he shaved the read calipers instead of ordering a new hub here is the link
http://www.benzworld.org/forums/w215...2002-cl55.html
Old Mar 25, 2011 | 10:29 AM
blue e's Avatar
1993 190E 2.3 S/E, 1996 E320, 1999 C43
To the OP: I have just completed the same upgrade you are attempting and you DO need to modify certain components on all four corners.
As momentum59 said, see my thread at the link shown above for more details.
BTW, the front caliper will not bolt on to you spindles. Not sure how you did that. You need to enlarge the hole in the spindle in which the caliper bolt (x4) passes through to a 5/8 in hole or metric equivalent. If you notice the correct bolts for the 8 piston calipers have an enlarge shank area so don't go by the diameter of the threaded area.
Do post some pictures when your done.
Old Mar 27, 2011 | 01:23 PM
momentum59's Avatar
I would like to complete my rear brakes this week if I have the time. and finding out write really gave me some hope to have this done soon! I just don't know how you shaved the rear caliper mounts exactly, when I test fitted the rears it seems like the caliper gets off line with the hub and the brake pads touching awkwardly. Note this is before any modification. could you please explain in depth if the shave is just a straight shave or is it diagonal? I attached a quick diagram i created in paint lol hope it makes sense whats going on here because its hard to explain. Caliper is in green, Pads in black, Disc is in dark grey, and Hub is in light grey. Please let me know if you have any questions, I will try to play around with them sometime this week and take a picture if we cant figure it out by then. Thanks for the help!
Attached Thumbnails need help with my break upgrade-brake-diagram-cl55-brakes-cl500.jpg
