CL55 Custom Exhaust
2003 CL55
[quote=benz_addict;4615820]Nice work!
I went with 3" from the headers to no cats at all, inplace a 3" dual x muffler then to reso's then mufflers.[/quote
That's interesting ! I haven't seen anybody do a X muffler ! How loud is it and how about the gas smell without the cats ?
PLATINUM SPONSOR
Did you cut open your resonators and remove packing? If so, why did you not take them off, since you have an X muffler up stream? I like your X muffler set up and have seen that on some other GM cars..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
2003 CL55
The late model GM you saw that setup on wasn't a CHEVELLE was it ?
Just giving you a hard time ! That is a different set up, but, without the cats he still has to be dealing with the fumes !!!!!
