Lowered The CL55 Thanks to Benz Wörks
Also what measurement are you at from from the ground to top of the wheel arch when you are at the lowest setting ? Front and back please
Thanks man, looks great !
R.K.
That's the module I purchased. Came with the remote. I ran the remote lines into the glove box in the car. I can tell/show you where to run the wiring harness through. Its very easy (once you figure it out).
One thing I must caution people on. The CL's wiring is backwards on two pins. You have to swap both the pins in the main harness and the 2 pins in the new "8" pin harness for it to work properly. Otherwise it raises the car in the rear instead of lowering it.
BTW that module is the exact same as the Renntech module. EXACT. The only difference is that it doesn't say Renntech on it.
R.K.
If that's right, then that is seriously cool. You guys keep making me spend money!
You have a couple of options.
1 is to turn off the module and it raises the car back up to factory height or 2 use the raise buttons on the dash. It will raise the car up and then once you're done going over the speed bump you just either turn the module on or press the button on the dash.
The lowering module just tricks the ecu into lowering the car but it still thinks its at factory height.
R.K.
R.K.
R.K.
