2003 CL55 door not sucking in
Behind the black hose you can see a metal thing and a white cover. I think this assembly popped open, I can reach my hand in there and there is a little wiggle room.
Can anyone advise me on how to fix this problem.
Thanks.
Does anyone know how I would go about getting the full technician manual on this car.
Thanks.
Many of us (myself included) have used zip ties and epoxy to repair the broken plastic vacuum/diaphragm you have taken a picture of.
I had to fix my vacuum trunk lock which had the same problem as well.
Your PSE pump will see that circuit open and go into fail mode thereby shutting down the pneumatic vacuum for that particular door. Once repaired you will need to pull the PSE pump fuse to reset the circuit that has been turned off.
epoxy is your best friend to repair the damage as the new parts are ridiculously expensive for what they are. the dedicated for plastics j&b weld two-part epoxy does wonders.
Here's the stuff: http://en.wikipedia.org/wiki/J-B_Weld
Is there a how-to on getting door panels off?
Remove aluminum cover on door end. Torx screws holding it on. Remove.
Pop SRS logo cover off and remove screw.
Pull to disengage tweeter triangle from door. Let hang loose.
Pop bottom of the door panel loose (all along the bottom). It is held on by several plastic molding pop holders.
Remove front A/C duct (Screw is hidden inside duct).
Once the A/C vent is off, you will see a black plastic slide piece above the seat controls. slide towards the rear of the door (spring activated) and the seat control module can be taken off by angling towards the inside of the car. Disconnect wiring and remove.
Reach into the hole that the seat control module once sat in and feel for a plastic handle. Pull the handle towards the inside of the door and the panel will release. Remove.
I guess Ill just pay the $800 to have it fixed.
Thanks for the ideas anyways.
See: https://mbworld.org/forums/cl-class-...500-trunk.html
Then I used some generic (glue type) 2 part epoxy and it is still holding strong.
OK, epoxy it is.
