minor problem with center storage compartment
This morning I discovered the hinge that's holding the upper portion of the compartment with the lower portion of the compartment is broken. Now whenever I press on the left side, which is suppose to pop up the top portion of the compartment would not work anymore, because the hinge is broken.
It is causing slight inconvenience, since now every time I want to grab something from the bottom compartment, I have to physically lift both layers up and everything in the top compartment will fall out since it is not attached together with the lid. Now to fix it, should I superglue the hinge, will there be a possibility that they both would be permanently be stuck together, thus eliminating access to the top portion of the compartment, or will everything turn back to normal?
