CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
How long does it take to raise the car?
Old Nov 15, 2011 | 05:22 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
So my question is, how long does it take for the car to raise back up after it has settled down while idling? Will it raise up after a couple of seconds? Minutes? Will it ever raise up just idling? Or do you have to press the buttons on the dash to raise it up?
R.K.
Old Nov 15, 2011 | 10:35 PM
ch33sehead's Avatar
2005 CL65 (current), 2001 CL600 (chopped)
About 1 second. It doesn't raise up while idling, you have to press the button to control whether to put it in the raised position or not.
Old Nov 15, 2011 | 11:19 PM
maxwerks's Avatar
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
if the car is idle , push the button ( Light on ) , it rises ... push it again , light off , it goes down .. thats it . The car never settles , unless left parked and not started for a long time .
Old Nov 16, 2011 | 09:40 AM
radride's Avatar
That's what I was wondering because its parked for the winter and won't be started till spring. Now I know what to expect.
R.K.
Old Nov 16, 2011 | 12:36 PM
Abbass's Avatar
Vechile 2009
I don't know if either of them are constantly updated, but they are both updated quite frequently. Sorry I don't really know what you mean >.<
_________________________
Window Tinting Santa Ana
Old Nov 17, 2011 | 05:05 PM
JHouse's Avatar
2014 CLS 550 & 2004 CL55
Caution. I once parked a car for a season and the engine turned to junk, all by itself.
Old Nov 18, 2011 | 02:35 AM
ch33sehead's Avatar
Most valve blocks will slowly leak after a long time so when you come back to it you'll probably find it sunk. When you fire up the car again and press the up/down button a couple times, it should spring back up to life. Or you could just put it on jackstands (also saves the tires from getting flat spots). And don't forget to put Stabil in fuel and disconnect battery...
