CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
cl65 transmission
Old Dec 19, 2011 | 05:40 PM
biker349's Avatar
cl600
cl65 transmission
need an answer. i was thinking of putting magnets in the pan of my transmission. someone told me it already has a magnet installed. can anyone verify?
thanks
Old Dec 19, 2011 | 09:30 PM
ch33sehead's Avatar
2005 CL65 (current), 2001 CL600 (chopped)
Almost all if not all modern trannies made in the last 15 years have filters. And by filter, I mean magnet. So yes, your tranny probably has several already strategically placed inside.
Old Dec 20, 2011 | 07:31 AM
saintz's Avatar
GL450
I believe my 1999 CLK and 2001 E55 did not have pan magnets installed. My 2003 CL600 did. I would assume all the CL65s would have them. It is an actual part you can order, so if you are changing the fluid or filter, you can add (another) one.
Old Dec 20, 2011 | 03:52 PM
biker349's Avatar
cl600
saintz, would you happen to know the part number for the magnet and maybe the cost?
thanks
Old Dec 20, 2011 | 05:27 PM
MBtech1098's Avatar
10 speed bicycle
Biker...Your car has them.
Old Dec 21, 2011 | 07:57 AM
SLCL's Avatar
CL55, SL500, E350
thanks
Your car should have them but adding a couple more would not hurt. Part number is 220 271 00 98. They are only a couple bucks apiece.
Old Dec 21, 2011 | 01:50 PM
saintz's Avatar
GL450
Yeah, they are cheap. You can get them on parts.com or from your dealer. They should be a stocking item since they use the magnet on virtually every car, at least the 722.6 transmission should all have the same magnet.
Old Dec 21, 2011 | 07:26 PM
dtohio's Avatar
05,cl65;33ford3wc.
Just a word of caution, I would keep magnets away from the trannys electronics, and even small parts such as the valve body. This applies to other areas as modern cars are full of sensitive electronics.
Old Dec 21, 2011 | 08:10 PM
ch33sehead's Avatar
2202710098 is superceded by 1693710003. Price is ~$20. Don't know why the newer style is so much more expensive.
Old Dec 22, 2011 | 07:24 AM
saintz's Avatar
GL450
The magnet should stick to the bottom of the pan. There are recesses that it fits into and won't go anywhere.
Old Dec 22, 2011 | 07:50 AM
grane's Avatar
GLK350, SL63 AMG
Don't forget to clean the magnet and replace the transmission filter in addition. Search on the forum for e,explicit instructions.
Old Dec 22, 2011 | 03:21 PM
biker349's Avatar
cl600
thanks guys. appreciate the info.
