CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
cl65 backspace offset question
Old Feb 1, 2012 | 10:27 PM
nola_penguin's Avatar
'18 Eurocharged GLE 43
Question cl65 backspace offset question
I know the rear offset is 60mm, but will 48mm clear the rear calipers?
Old Feb 2, 2012 | 10:57 AM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Offset has nothing to do with clearing calipers. The face of the wheel or "disk" type determines that. But to answer your question, if you stayed with the same sized wheel (9.5) and got a 48mm offset, your wheel would move out a total of 12mm.
R.K.
Old Feb 2, 2012 | 10:59 AM
radride's Avatar
BTW this is what happens when the offsets work but the disks don't clear the calipers:
https://mbworld.org/forums/cl-class-...-rim-help.html
R.K.
Old Feb 2, 2012 | 11:02 AM
I knew some about offset but should have researched more before I posted. I need to make sure the pad space allows enough room to clear the calipers. I'll measure that. moving on 12mm is fine. Thanks.
Old Feb 2, 2012 | 11:10 AM
radride's Avatar
I ordered my set of wheels for my CL65 a month ago. I should have them in 2 months. Going to be running a 20x9 on the front and a 20x10.5 on the rear.
R.K.
Old Feb 2, 2012 | 03:25 PM
Damn wide!! Can't wait to see what they look like. I just measured the pad space. You have 1.25" from where the hub ends to where the caliper needs to clear a rotor. As long as you have that, you'll clear both the front and rear calipers fine. That's with about .25 of clearance, too. You could do it at 1" but that is too damn close for my taste.
Old Feb 2, 2012 | 05:38 PM
radride's Avatar
I know. I've done all of my research. It took me over 3 months to figure out the ideal fitment. I will post pics of the car once they are on. I will be running a 305 out back as well. If they fit how I think they will fit with the offset I chose, it will be money. BTW I won't give out any specs on the wheels.
R.K.
