Realignment necessary if lower 1 inch?
- all they do is try to create and enforce new crimes at the rate of hundreds of thousands per year).
Back on point: So I figure since you can raise and lower it about an inch and a half with the dash button, lowing it another inch back to the original design can't certainly can't screw it up. So am I in the clear?
I checked my tires and they are wearing down unevenly on the driver side....I will probably have to get an alignment soon. I also use the ABC button a lot for dips, curbs, etc do you think that has anything to do with it?
Maybe you need to lose some weight??? Just sayin.
R.K.
The bad news is that W215's eat tires quick due to the negative camber.
http://www.ozebiz.com.au/racetech/theory/align.html
it would be kinda absurd to get an alignment every time I use it, but i'd rather ask and be safe than sorry lol
tire wear on driver side after drop and never aligning....
R.K.
Hitting sport mode does not lower our cars, that's only in the E55 and CLS55.
For us it just stiffens up the shocks for better handling.
Edit: just remember this from wikipedia
Active Body Control, or ABC, is the Mercedes-Benz brand name used to describe fully active suspension, that allows control of the vehicle body motions and therefore virtually eliminates body roll in many driving situations including cornering, accelerating, and braking.
In the ABC system, a computer detects body movement from sensors located throughout the vehicle, and controls the action of the active suspension with the use of hydraulic servomechanisms. The hydraulic pressure to the servos is supplied by a high pressure radial piston hydraulic pump. A total of 13 sensors continually monitor body movement and vehicle level and supply the ABC controller with new data every ten milliseconds. Four level sensors, one at each wheel measure the ride level of the vehicle, three accelerometers measure the vertical body acceleration, one acceleration sensor measures the longitudinal and one sensor the transverse body acceleration. At each hydraulic cylinder, a pressure sensor monitors the hydraulic pressure. As the ABC controller receives and processes data, it operates four hydraulic servos, each mounted in series on a spring strut, beside each wheel. Almost instantaneously, the servo regulated suspension generates counter forces to body lean, dive, and squat during various driving maneuvers. A suspension strut, consisting of a steel coil spring and a shock absorber are connected in parallel, as well as a hydraulically controlled adjusting cylinder, are located between the vehicle body and wheel. These components are prone to failure, hazardous when fail, but adjust the cylinder in the direction of the suspension strut, and change the suspension length. This creates a force which acts on the suspension and dampening of the vehicle in the frequency range up to five hertz.
The system also incorporates height adjustable suspension, which in this case lowers the vehicle up to 11 mm (0.43 in) between the speeds of 60–160 km/h (37–99 mph) for better aerodynamics, fuel consumption, and handling.
The ABC system also allows self-levelling suspension, which raises or lowers the vehicle in response to changing load (i.e. the loading or unloading of passengers or cargo). Each vehicle equipped with ABC has an “ABC Sport” button that allows the driver to adjust the suspension range for different driving style preferences. This feature allows the driver to adjust the suspension to maintain a more level ride in more demanding driving conditions. It was introduced in 1999 on the top-of-the-line Mercedes-Benz CL-Class. This system is standard on all Mercedes-Benz SL (except for SL350) and CL Class models and on S Class (only S600, S55 AMG, S63 AMG and S65 AMG) models sold in the U.S.
Once you lower the car using a lowering module, the auto lowering of the car at highway speeds gets bypassed and your ride height never changes. Some models of Benzes are different.
R.K.
You betcha. I like the idea of having a solid ride height so I went with my lowering module. Besides its easy to resort to stock height. Takes 2 secs by turning off the module.
R.K.
I need to GAIN some weight if anything! I've been 160 lbs since high school ....which is pretty sad
