CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Car is trippin out, someone please help me out!
Old Mar 29, 2012 | 05:38 AM
JPhamily's Avatar
Mercedes CL55
So today I went to Walmart to pick up a couple things, when I came back out to start my car it wouldn't turn over. Nothing happened when I turned my key. all the electronics like the cluster and radio but the car didn't turn over at all. It didn't even crank. I had to try it a couple times then it finally started but when it did the cluster had this thunder bolt on it saying display malfunction and then it popped up asb and esp needs to be checked. None of my speedometer were working. The needles weren't moving. I drove the car and noticed it was stuck on first gear and wouldn't switch to the next. I stopped the car and turned it off and started it again an everything went away and back to normal. Went back home to try the car again and something happened. Someone help me please, let me know if you guys had this happen before or if you know whats going on. I just had my crank sensor replaced a month ago so I know its not that.
Old Mar 29, 2012 | 07:53 AM
slonar21's Avatar
CL600 2003
Maybe battery
Old Mar 29, 2012 | 07:55 AM
hyperion667's Avatar
2012 CLS63
maybe wal-mart?
Old Mar 29, 2012 | 10:12 AM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Originally Posted by slonar21
Maybe battery
How old is the battery? Maybe its the alternator.
R.K.
Old Mar 29, 2012 | 10:09 PM
JPhamily's Avatar
Mercedes CL55
I brought the car to a local Mercedes shop. Turns out to be bad pulleys which is effecting my alternater so I'm getting it replaced. Thanks for the help guys.
