CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Cl55 amg supercharger problem help!
Old Apr 7, 2012 | 02:11 PM
mbcl55amg1's Avatar
Cl 55 amg
I've had my cl for almost 3 years now for the past 2 years the car has been a beast but the past couple of months have been hell my sc only engages in the am and after a few min it shuts off and runs on engine power it's like jumping from a horse to a donkey anyway I took it to a performance show changed the clutch the ic pump, conductor plate on the tran,plugs etc. is there anybody else goin through the same thing ?
Old Apr 7, 2012 | 02:27 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Check your intercooler pump again.
R.K.
Old Apr 7, 2012 | 02:31 PM
mbcl55amg1's Avatar
Cl 55 amg
I did I had it rewired and all this is driving me insane
Old Apr 7, 2012 | 04:30 PM
Sher Judge's Avatar
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
Make sure you have no air-locks in the cooling system.
As said above, keep on checking your IC-Pump, maybe, just maybe the new pump is defective. I hope so. If, it is the pump.
Old Apr 7, 2012 | 05:04 PM
radride's Avatar
What ic pump are you running op?
R.K.
Old Apr 7, 2012 | 05:11 PM
mbcl55amg1's Avatar
Cl 55 amg
Cm30 which was recommended and installed by a performance shop.has anybody else delt with the same problem
Old Apr 7, 2012 | 05:16 PM
radride's Avatar
I heard those pumps crap out often and don't last. I betcha it crapped the bed again.
R.K.
Old Apr 7, 2012 | 05:25 PM
mbcl55amg1's Avatar
Cl 55 amg
So should I just go bak with the Bosch pump?
Old Apr 7, 2012 | 05:37 PM
Sher Judge's Avatar
Bosch 0 392 022 010
MB 000 500 03 86
This will have you sorted, it's a Heavy Duty pump.
Old Apr 7, 2012 | 05:42 PM
radride's Avatar
Originally Posted by Sher Judge
Bosch 0 392 022 010
MB 000 500 03 86
That's what I'm swapping in my CL65 in the next couple of days.
R.K.
Old Apr 7, 2012 | 05:48 PM
mbcl55amg1's Avatar
Cl 55 amg
Do u think that could be the problem ?
Old Apr 7, 2012 | 05:57 PM
radride's Avatar
In my opinion and from what I read, the supercharger dis engages when the intake air temps get too high such as the intercooler pump failing, air in the system or the sensor itself goes bad. Just take it in and get it checked out for sure.
R.K.
Old Apr 7, 2012 | 06:39 PM
Sher Judge's Avatar
R.K.
Sweet.
Old Apr 7, 2012 | 06:50 PM
mbcl55amg1's Avatar
Cl 55 amg
Could it also be the iat bc I notice in the morning wen I start it up the temp gauge shots up in a few min
Old Apr 8, 2012 | 04:19 PM
Raff's Avatar
89 e30 325is, 03 CL55, 2011 Toyota Sienna SE
I had the same problem before and replace my IC-pump with the John CM30 from Benzworks (Serge). After I did that I haven't had any problems. I have done multiple pulls in the high desert and the supercharger didn't shut down to limp mode.
Old Apr 8, 2012 | 04:58 PM
mbcl55amg1's Avatar
Cl 55 amg
I'm gonna buy the new Bosch pump bc the cm30 wasn't so reliable
Old Apr 10, 2012 | 01:19 AM
559cl55amg's Avatar
2003 cl55 amg, 2008 Range Rover Sport SC
I am experiencing the same exact thing. I can do one run smashing hard. When i come to a stop and try to smash, my sc is disabled. Runs horrible!!!! Only happens when i smash hard.I was about to post a thread about this. So I'm looking at a bad ic pump? My car is practically stock. What am i looking at for a new pump?
Old Apr 10, 2012 | 01:36 AM
kustom2k1's Avatar
03SL55
Bad pump most likely culprit. OP sounds like you have air in the system..bleed it and beat on it.
Old Apr 10, 2012 | 04:03 AM
559cl55amg's Avatar
Who is op?
Old Apr 10, 2012 | 09:55 AM
radride's Avatar
Originally Posted by 559cl55amg
Who is op?
Original Poster
R.K.
