CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Programa / Renntech V2 Module...Rear Raises When Should Lower
Old May 19, 2012 | 02:13 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Hello,
Has anyone installed the Programa/Renntech V2 lowering module with remote on his CL? My front works perfect, but the rear raises instead of lowers when you control it through the controller...any insight?
That's as low as a CL will go
Old May 19, 2012 | 11:13 AM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Originally Posted by OCKlasse
Hello,
Its very common on the CL. You didn't get the proper instuctions. For the rear, the wiring is backwards. I had the same thing happen to me. I will have to see if I still have my instructions.
R.K.
Old May 19, 2012 | 02:22 PM
fatmike's Avatar
CLK63 BS
Same happened to me LOL.
Old Aug 23, 2013 | 01:17 AM
Soopreme's Avatar
W220 S55 AMG
Bringing this back from the dead. How did you guys end up fixing this issue? I'm having the same problem. Thanks
Old Aug 23, 2013 | 01:27 AM
OCKlasse's Avatar
MBworld Guru
I believe the rear corners had to be swapped in the wiring, so that the driver rear went to the passenger rear and vice-versa.
Old Aug 23, 2013 | 09:02 AM
AndreNY's Avatar
couple of Benzos
Getting my V3 installed next week hopefully I wont have the same issue LOL
Old Aug 23, 2013 | 02:55 PM
radride's Avatar
Read my answer here in post 4 and 7:
https://mbworld.org/forums/cl-class-...uld-lower.html
R.K.
