Performance Question
1 Post
03' CL55 AMG
I did a search but couldn't find my answer so i hope this hasn't been posted..
I wanted to know what kind of performance increase would come from the following that i have had done to my car:
• Johnson Water Pump
• AFE Filters
• Resonator delete
From what i've read the pump can give as much as 25 HP, and the Filters and Resonator delete can give up to 7HP and 3HP respectively
Thanks in advance
• AFE Filters
• Resonator delete
Thanks in advance
Pump won't give you any more power but the power you do have will be more consistant. The filters are anyones guess.
R.K.
R.K.
1 Post
w215 cl65, W212 E63, R53 Mini Cooper JCW, E92 328I
+1 also you will not feel any increase from filter and resonator delete.. you prolly got around 10hp max from filter and resonator delete. and thats prolly 1hp to the floor, and theres no way you can feel that.. u prolly just feel the car more smooth and the acceleration is more snappy
with all respect, don't be fooled if anyone told you that you got gains from those mods. If anything, your car is running efficiently, and will use it's already had power more efficiently.
If your looking for performance, spend time at the W211 AMG section, same engines. Just do pulley, headers + TUNE (I recommend Eurocharged) and you will be amazed.
