headlamp question
headlamp question
hi Guys,
i bought a '10 cl63 last week and couldn't figure out how to turn on the inner headlamps. anyone please help? thanks. please see attached photo
CL500
So I checked an online manual on a 2009 CL63, it indicates that it is IR emitter (for Night
View Assist) using H11 (55W) bulbs. Also on the manual under the same section, it is a "high beam flasher lamp.
Whether or not it turns on I was unable to find. Try turning up your headlamp switch all the way right and then turn on your high beam (pull the stalk to hold high beam) and see if it lights up. However since you mentioned your low beam got brighter (bi-xenons) then I don't really know.
My 07 550 low beam also brightens up but the inner lamp also lights up, it is not a projection style housing like the one pictured though.
http://www.mbusa.com/vcm/MB/DigitalA...mg_cl63amg.pdf
