Car raises when in park?
Mercedes CL55
Whenever I have my car on and on park for a while, I notice that it raises and then drops back down when I put it back to drive. My car is lowered on links and Im basically maxed out. My car raised up like a 4x4 then dropped back down. This wasn't the first time ether. Have any of you guys had this happen before and would like to explain why its doing that
Maybe one of the sensors got messed up when you installed the lowering links? Mine doesn't do that but its lowered using the module.
R.K.
R.K.
The first time, it freaks you out! I have no idea why
2003 cl55 amg, 2008 Range Rover Sport SC
I just got my abc pump replaced. My car would do the same before abc took a dump. Tech adv that car raising is a sign of pump going out. Cars computers knows system is loosing pressure so for safety it raises to highest level. Hope I don't scare you
i'd wait till you get a warning message before replacing the pump. i your paranoid have someone check with the star diag. system.
or as i said you can have it checked with star diagnostics to see if it finds a fault.
