CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Does the Airmatic Suspension Struts of a W221 S class fit a W216 CL Class???
Old Oct 31, 2012 | 12:28 PM
rcgalore's Avatar
E 63 Type S 2014
Does the ABC Suspension Struts of a W221 S class fit a W216 CL Class???
Hello:
I think I might need to replace the front passenger strut of my CL 65....
Can anyone tell me if the W221 struts are the same and they will fit..??
Also, any place where I can get them at a more reasonable price..??
NOTE: This is based on being both ABC struts, not Airmatic.
Answers appreciated.
Regards
Old Oct 31, 2012 | 04:51 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Its not going to work because the CL65 is ABC and not airmatic.
R.K.
Old Oct 31, 2012 | 05:25 PM
C280 Sport's Avatar
MB’s of all kinds.
R.K.
Correct!
To the OP. ABC, Active body control is the modern day high tech implementation of Anti Sway Bars. It is independent of the traditional Spring/Shock or in mercedes implementation AirMatic suspension. ABC, always was a high pressure hydrolic system, Hydraulic being that is uses fluid and air pumps . The Hydraulic system in ABC operates at a fairly high PSI of around 3000 PSI if I think correctly, which needless to say involves precision everywhere as a Mercedes does. (assembly, maintenance, quality parts, yada, yada)
AirMatic is a way of combining the Spring and the shock into a system that uses "Air". All of the S550's have Airmatic suspension. The individual order option ABC is just that , it could be ordered independently, but was meant to enhance the stock Airmatic suspension
My 600 has ABC and it is a closed system.
Old Oct 31, 2012 | 05:28 PM
rcgalore's Avatar
E 63 Type S 2014
Ok. I just edited my question....
Then.. An ABC strut of an S model 2008 and up... Will it fit a CL 2008 and up..??
Old Nov 5, 2012 | 07:23 PM
NEWME's Avatar
rcgalore, please check your PM.
For everyone else might be interested, I got 2 perfectly functional used ABC struts off a 08' W216 CL63 for sale with 35k miles on them.
Old Nov 6, 2012 | 08:37 AM
biker349's Avatar
cl600
how much were the strutts and where?
