CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
How to: Change your spark plugs *Video* with part numbers/tools list, etc
Old Dec 6, 2012 | 08:23 PM
nidyanazo's Avatar
550HP+ ///AMG CL55 Kompressor, Ducati 916bp, Yamaha R1 WSBK replica
Exclamation How to: Change your spark plugs *Video* with part numbers/tools list, etc
Thought some may find this useful. Sorry my camera was in low resolution mode when I filmed it
Old Dec 7, 2012 | 04:15 AM
nidyanazo's Avatar
Makes a feel-able difference, at least it did for my car. The slight idle stumble is completely gone, and the engine is smooth as glass at idle!
MAKE SURE to push in the metal plug boots all the way until you hear the click sound. It takes quite alot of force to do so, but if you don't then they will not seat correctly.
Old Dec 7, 2012 | 04:58 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
The hardest part of the whole procedures is how to remove the plugs boot without the right tool. Most of us used the open end wrench to pry out the plug boot. What did you used?
Old Dec 7, 2012 | 05:01 AM
nidyanazo's Avatar
My hands. On the left side, the very last plug I used a vice grip/lock jaw. That was the only one I couldn't get undone without a tool. My trick was to twist and try to spin the plug boot, and that way they come off easier.
Old Dec 7, 2012 | 12:15 PM
awiner's Avatar
2003 CL55 AMG
Labeling the plug boots isn't entirely needed.
If you look at the heads, you will see Mercedes has given us a nice alpha diagram (A, B, C, D, E). The plug boots have this letter on them to indicate location.
Also, if your going through the process of changing plugs, test your resistance on the plug wires. When I changed mine at 100,000 miles, the resistance on some of the plug wires was high.
I ended up replacing the enter wire set as well.
Also, a little dab of DI-electric grease on the spark plug or smeared on the inside of the boot will help ease of installation as well as DE-installation the next time you need to pull the boot.
I also use a dab of anti-size on the spark plug threads.
Old Dec 7, 2012 | 04:36 PM
PelicanParts.com's Avatar
SPONSOR
Great video! Just out of curiosity, what else have you done?
Old Apr 1, 2019 | 02:52 PM
2006 CL500's Avatar
2014 E550
How many miles on those plugs?
Old Apr 23, 2019 | 11:46 AM
ctravis595's Avatar
2002 CL500 to CL55 conversion
2006 Cl500- nidzanyo is a royal douche and has been banned for a long time. might be able to get a hold of him through his youtube channel
also there are different styles of plug wires, there's a Beru brand which is also OEM but the 16mm mercedes spark plug wire tool wont work. hope this helps someone before they get upset at the tool they ordered, and wont work...
