CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
License Plate Bulbs Flicker and go off. Any Help?
Old Jan 24, 2013 | 09:51 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
I'm already on my second set of LED License Plate bulbs and nothing seems to fix the issue. Are my bulbs just bad or is there something wrong with the car? Anyone had these issues before?
KAMIL
Old Jan 24, 2013 | 09:57 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
I think the bulbs are just bad. I've had to go through many sets. It's annoying.
Old Jan 24, 2013 | 11:05 PM
alx's Avatar
alx
You need compensated bulbs. Mercedes cars measure resistance/ wattage a bulb is drawing to determine if it is blown. If resistance is not within specs (ie too low or short) bulb is considered blown and current is not supplied any more to bulb.
Flickering is a good indication the bulbs are not compensated and because they are LEDs they draw less wattage causing the sam to think they are blown. You should also get a message on the dash.
Old Jan 25, 2013 | 01:45 PM
Do you know where I can get these bulbs in LED ? or at least brighter form and not he OEM yellowish ones
Old Jan 25, 2013 | 07:15 PM
Blkvip's Avatar
12' E559
v leds or itoyjdm I believe is the name. they sell ones with resistors
Old Jan 25, 2013 | 07:45 PM
3WD's Avatar
3WD
SPONSOR
Car
Hello,
Are the LED bulbs you're installing CANBUS bulbs?
Old Jan 25, 2013 | 07:50 PM
Blkvip's Avatar
12' E559
canbus hmm wanna say no. I just got the "euro" ones. did my front drl's and license no errors.
Old Jan 25, 2013 | 08:05 PM
3WD's Avatar
3WD
SPONSOR
Car
Hello,
If you purchase the good quality Canbus/No Error LED bulbs you shouldn't have any problem.
Well if you want to try another set, we can sell you a pair for $15.99 Free Shipping.
Just reply back with your PayPal information so we can process the order.
If they don't work for some reason, we will offer you full refund.
Thank you
Old Jan 26, 2013 | 04:28 PM
danlnyc's Avatar
04 CL55 (sold), 2012 CLS550 (sold), 2014 S550 (sold), 2015 ES300H (DAILY)
you should check to see if moisture and water is able to seep inside the LED holder thing. I had an issue with my lights flickering too and I found out it was because moisture kept getting inside. After I sealed it off and bought new lights, the issue disappeared.
Old Jan 27, 2013 | 09:54 PM
Originally Posted by 3WD
Hello,
Thank you
PM sent
Yea there was moisture inside I guess I didn't lock em up tight enough last time when i put them in. I will order from the vendor above once again and this time lock them up nice and tight.
Old Dec 11, 2013 | 10:57 AM
junctionvip's Avatar
mercedes cl500
If you add in a resistor for each bulb the issue is no longer
Old Dec 13, 2013 | 02:42 AM
JPhamily's Avatar
Mercedes CL55
My license plate leds do the same thing.. so annoying
Old Dec 14, 2013 | 11:34 AM
Go with 3WD cendor on here I bought a set for SL55 E63 and now my CL and they are perfect with no issues ran them on my SL for over a year never gave me problems. Same with the CL over 6months going strong my E63 buddy has no complains either
Old Feb 23, 2023 | 08:24 PM
SL55Sherv's Avatar
SL55 AMG
I'd like to order led license plate set for my 2003 SL 55 please
Hello,
Thank you
Thank you!
-Sherv
