CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Motor issues? please help
Old Feb 12, 2013 | 08:55 PM
Madys55's Avatar
2003 CL55 AMG
So I have a 2003 Cl55 and my parents drove it one night and when they got to a stop sign the car started to act as if it were going to stall then my mother smelled gas. They parked the car and when my dad went to start it back up, the car had trouble starting at first then white smoke came out of the exhaust once it started. I took a look under the hood and I smelled gas. I had it towed to a shop that I know and they told me my starter burnt out. We replaced the starter and the car still has a horrible clunking noise like something is stuck in the motor. Any ideas of what it may be? What I can do to fix it without spending half of what the car is worth to rebuild the motor?
Old Feb 12, 2013 | 09:08 PM
alx's Avatar
alx
White smoke- coolant.
I would guess you blew a head gasket. Not common at all especially on non- modified engines.
Could be many things though. Let us know.
Old Feb 12, 2013 | 09:11 PM
Madys55's Avatar
2003 CL55 AMG
Will do, guy at the shop thinks motor might need to be rebuilt. My friend thinks my cat's insides broke apart and got sucked into the motor. Me, im lost, angry, and sad at the same time.
Old Feb 12, 2013 | 09:13 PM
Madys55's Avatar
2003 CL55 AMG
also alx I dont think this would cause a clunk in the motor
Old Feb 12, 2013 | 09:25 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Doubt you blew a head gasket and no cat material is in your engine either. I would not keep changing parts and do a leakdown test on the engine ASAP. These engines doub wear out easy in stock form, that is if your car is 100% stock and not been moded.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Feb 12, 2013 | 09:55 PM
Madys55's Avatar
2003 CL55 AMG
Thank you Exotic-metal, the only "mod" I have on my car is deleted resonators. Other than that shes bone stock. Nothing fancy. The car does not leak, or anything like that (that ive noticed). nothing in my garage, or anything like that. Mechanic friend of mine told me that the cat could be clogged and creating issues. Going to investigate further tomorrow
Old Feb 12, 2013 | 10:04 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
The cats are after the motor and in the exhaust. There is absolutely no way that any cat material made it back inside the motor. I agree with Exotic-Metal, get a compression test done. Maybe it has something to do with the supercharger. I'm not sure if its water cooled but if it is, maybe a line let go causing coolant to go into the motor .
R.K.
Old Feb 12, 2013 | 10:51 PM
alx's Avatar
alx
Depending on where it is blown a torn gasket can make very mechanical- sounding racket/ knocking sound.
Old Feb 13, 2013 | 04:58 PM
Madys55's Avatar
2003 CL55 AMG
update: car starts but sounds like its getting cut off then shuts off 5 seconds later. still thinking my cats are clogged completely : /
Old Feb 13, 2013 | 06:02 PM
alx's Avatar
alx
did anybody actually read the car?
Old Feb 13, 2013 | 06:56 PM
awiner's Avatar
2003 CL55 AMG
My initial guess is your having a fuel delivery issue due to the "stumbling" and smell.
Have the codes read and a mechanic check the obvious.
Old Feb 13, 2013 | 09:47 PM
Madys55's Avatar
2003 CL55 AMG
you are correct, its dumping fuel. Mechanic says one of the injectors is stuck open.
Old Feb 13, 2013 | 10:08 PM
alx's Avatar
alx
I have seen that on another 03 55 kompressor motor. The final result was a broken intake valve and a $4000+ bill.
Old Feb 13, 2013 | 10:24 PM
zneB-sedecreM's Avatar
MB; 55KCL AMG, SL550 SLS AMG G500 Cabrio 280SL ML350 CLS550 ML500 E55 AMG CL500 S600 SLK32 AMG
Damn
That's the price of OliverK's entire car...
Hope you can get it fixed for cheaper. Good luck
Old Feb 13, 2013 | 10:44 PM
Madys55's Avatar
2003 CL55 AMG
was this at a dealership???? that seems like a lot of money lol
Old Feb 13, 2013 | 11:41 PM
layzie12g's Avatar
2008 Mercedes Benz E63
The cats would rattle before they failed completely and blocked the secondarys. Ask me how I know. My car still ran, but I had to baby it home.
Old Feb 14, 2013 | 01:02 AM
BR34K3R's Avatar
04 CL55, 04 SL55, 2013 Panamera GTS, 1987 944 Turbo 420WHP, 04 Dodge Viper, 2011 E550, 2013 Accord
Check your injectors, could be an open injector. Cats would not cause that problem and blown head gaskets are very uncommon. You can also have the mechanic perform a leak down/compression check...But like I said before these motors are pretty much bullet proof.
Also check your engine bay for tree nuts or rat droppings, sometimes rats will get in there after you stop because its warm and they dont mind chewing on your many wires while they are there.
God Bless,
Last edited by BR34K3R; Feb 14, 2013 at 01:03 AM. Reason: spelling, i think i got it all.
