Intake Dreams
-- Connect the intake air to the cowl plenum below the windshield - old hotrod trick. Cold air, pressurized air. The M113 has it's mouth at the back of the engine anyway...
-- Modify a M113E N/A intake manifold so that the throttle is at the front of the engine. Shorter route to the intakes each side of the radiator, colder air.
Filtration a challenge with either idea. Just thinking out loud.
You have an Excellent open mind my friend....
Moreover; if can modify the Throttle mouth to install "82mm" Throttle body,,
Im soo surprise, why Performance shops won’t go with this Extremely modification benefits.....
ZAYED,,
