CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Transmission knock
Old Apr 18, 2013 | 04:27 PM
MichaelGuerrero's Avatar
2006 CL500
Transmission knock
Hello All,
I have a 2006 CL500 with 160k miles. Recently it was parked at decline facing forward. It sat for a few hours and when I went to move it, reverse would not engage, put it in drive an nothing. Put it back in reverse and revved it a little higher and it engaged with a loud thunk. Against my better judgement I drove it at low speed to see if sound would go away and it did once I was above 30-40 mph. Proceeded on the highway and the car was shifting fine and no noticible noise. It seemed once I reduced speed to under 40 mph the sound was more apparent, although shifting fine. I inspected the flex discs and they seemed fine. Sent it to the dealer for diags and they said, "something in the trans, gonna need a new one" $5,500. Any ideas, could it be low fluid?
Old Apr 18, 2013 | 10:48 PM
alx's Avatar
alx
"Something in the transmission" sounds about right...
Lower speed pretty much means lower gear.
I would take it to a good transmission shop and have it rebuilt. This is a known 5-speed tranny that is shared with a lot of chryslers. Shops know them and can rebuild them for far less. The dealer is quoting you a new tranny.
Old Apr 20, 2013 | 07:51 PM
dtohio's Avatar
05,cl65;33ford3wc.
I assume this is a 7 speed. The dealers you need a new one sounds like a gess. Could be many things, the low fluid level could be it, my 04, 7sd was a little low and it got shift wacky, also I had a conductor plate get intermittent and similar effect, get another diagnosis, good luck.
Old Apr 20, 2013 | 07:59 PM
alx's Avatar
alx
My bad. I read cl600 so I assumed it was the ubiquitous 5-speed.
The 7-speed is not easily serviceable states- side.
Old Apr 20, 2013 | 09:54 PM
chazcon's Avatar
2002 Mercedes-Benz CL55 AMG
here mate: https://mbworld.org/forums/cl55-amg-...sion-woes.html
