ABC issue - Valve block ?
Hi guys,
I've noticed that my car sinks from time to time but only rear right side to the extent that tire is almost at the level of right rear wheel arch.
I see this issue on average once in ~7 days and I drive the car daily. I also tried to top off the ABC fluid but looks like it didn't help.
Any suggestions ?
Thanks !
Any suggestions ?
Thanks !
Changing the ABC fluid might help, but its probably down to worn or contaminated seals in the rear valve block. Sounds like you just need keep an eye on it - maybe cycle the suspension up and down a few times to get the fluid moving around.
Nick
Nick
12' E559
check the valve's see any leaks? im guessing no since it takes 7days so as welwynnick said prob a worn seal. you could also check the abc pressure see if its with in spec. like 190bar or something....don't quote me through
