CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
info. on autel md802 obdII scanner
Old Dec 15, 2013 | 08:02 AM
biker349's Avatar
cl600
anyone used the autel md802 obdII elite mxdiag graphing scanner? supposedly does the same diagnostics as a star system. hard to believe, but would like your input and does it do the rodeo?
thanks
Old Dec 15, 2013 | 09:15 AM
alx's Avatar
alx
I read the product description. Didn't sound like anything more than an obd 2 scanner. The das setup is so much more.
Old Dec 15, 2013 | 12:28 PM
awiner's Avatar
2003 CL55 AMG
The MD802 is a nice OBDII scanner with a LCD screen for easy navigation and monitoring/recording of some live data streams.
It will not access most the modules in a Mercedes however and certainly can't do the actuation's nor programming/coding DAS was made for.
Old Dec 15, 2013 | 05:08 PM
biker349's Avatar
cl600
will it do a rodeo? what inexpensive scanners can do rodeo?
Old Dec 15, 2013 | 10:10 PM
awiner's Avatar
2003 CL55 AMG
Nope. That is an actuation. Nothing 'inexpensive' will do it.
The only devices that I know will preform actuations other than DAS/Xentry was a Chinese produced unit. I forgot the name and manufacture, but it was just as expensive if not more than a good DAS clone.
The other is a Carsoft mux with later generation software. Again a pricey unit vs a clone.
I have a early version of the Alpha-Bid unit with Carsoft software that I used before I had the real DAS system. I wrote a review on it here: https://mbworld.org/forums/mercedes-...ic-reader.html
I still have that unit too. I should sell it since after buying a DAS clone I won't go back :-)
