My ABC Delete Thread
Again, OP feels adventurous so it's all good. That's not to say though that ABC is badly designed, unreliable ticking bomb. Keep an eye on it and enjoy it. I realise that this is not an "ABC vs" thread so apologies for taking it off-topic.
If the hose is sweating, it must be replaced or repaired - then you'll be OK. No need to pay MB prices, either.
Nick
I'll keep everyone updated. I received all of the parts necessary for the power steering pump conversion.
Nobody is pointing fingers I'm just saying that its a great project and who ever thinks it's not have the right to their own opinion. Sure we are all enthusiasts but I also had a million people saying "why? and don't do it" when I was building my SL55 AMG. I know OC is going his own route and is set on his decision because of doing this thread and moving forward. I just want to show some support and say good luck. You are not the only one on this forum that would not do this project, if I had as much knowledge about the car and a kit in works I would go OC's route.
The only thing holding up the project at this point are the rear struts. Since I like to go low, I am running into problems. When I attempted to replace the ABC strut with another strut, the backside of my wheel was hitting the strut at full drop due to the camber and my rear wheel width (10.5").
Currently working to correct this. Easy way is just being able to tub some of the rear fender well to create more clearance. Hard way is fabricating new lower control arms with seats and then adding mounts onto the rear subframe.
Note this is all in my pursuit of low, and really has nothing to do with someone wanting to do a coilover-type swap that would not go lower than the factory tolerances permit.
SPC products has some offset camber bushings for the upper arms in back to correct negative camber (or add it if desired), for several different MB models...Will any of those work on your CL?
