CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Check Engine and Exhaust Sensors
Old Feb 2, 2014 | 11:45 PM
CL600CK60V12's Avatar
2008 S65 AMG, 2005 SL65 AMG, 2005 Porsche Carrera, 2011 Shelby GT500, 2001 Acura CL Type S
After replacement of sparkplugs and service B on CL600 Carlsson (2003), I got a 'check engine' light, took it back to the dealer, they read the code and determined that the 'exhaust sensor' is throwing the code and they'd need more time to investigate.
Spark plugs were (carefully) installed at the dealer and coil packs are healthy.
Is the exhaust sensor the 'O2 sensor' or something else? Do they have to be replaced at regular intervals? No noticeable effect on driving - car is at it smoothest it has ever been.
I did not have the time to leave the car again for diagnostics but I will do that later in the week. Technician just said that it was the 'exhaust sensor throwing the code' but he could not see what was wrong with it. Cleared the code. I drove the car for several days and then 'check engine' came back.
Compared to my other cars, this one needs most 'babysitting' )))
Thank you
S.
Old Feb 3, 2014 | 11:39 AM
Dr Matt's Avatar
05 CL65
Yes, it is the O2 sensor. They have a limited lifespan so eventually are a replacement item just like your spark plugs.
Old Feb 3, 2014 | 07:13 PM
Purge valve
thank you. I called again today and they said it was the "purge valve" which may be "sticky." It should be one of those low-cost repairs for the CL
