CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Help on an 05 CL65
Old Mar 22, 2014 | 02:35 PM
Snakey's Avatar
2005 CL65 AMG
Help on an 05 CL65
Greetings all! Have a 05 CL65 that's likes to die immediately after startup when cold. Does it pretty much every time. She'll fire up run for a brief moment then die. Immediately starts back up again and will stay running. Doesn't seem to happen once warmed up but puzzling none the less.
She's a cream puff with only 26k miles on her. Came from a producer/collector in CA. Trying to gain as much knowledge as I can on the ins and outs and thought this looked like the best resource online!
Thanks!
Ryan
Old Mar 22, 2014 | 05:50 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Check if your vac line did not come off. Does it run rough like its chocking? Maybe the fuel pump is shutting off?
Old Mar 22, 2014 | 09:48 PM
Snakey's Avatar
2005 CL65 AMG
Seems to run just fine once you restart it. No weird idle or roughness to it. Might need to start looking around for a loose vac line I guess.
It's weird because it just shuts right off like you turned the key off. No drama about it.
