CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Disabling Speed Sensitive Lowering (W215)
Old Mar 22, 2014 | 03:50 PM
capn_shawn's Avatar
2005-CL55, 2006-R350
Duh, I just realized that our cars have "Speed Sensitive Lowering"...
First: Does anybody know how much it lowers?
Second: Is there a way to disable this or limit it using the STAR system?
The car is a 2005 CL55 lowered with adjustable links to run about 1.25" below stock ride height as a daily driver. The alignment is near perfect, but during alignment it was noted that there is quite a camber/toe difference from normal ride height to the top/raised position. I can only make the assumption that going lower will result in extra camber or toe at highway speeds.
Any thoughts?
Old Mar 23, 2014 | 07:38 PM
awiner's Avatar
2003 CL55 AMG
Lowers 11 mm (0.43 in) between the speeds of 60–160 km/h (37–99 mph) .
There is no way to disable via STAR. This is one of the main reasons I went with a lowering module.
Old Mar 26, 2014 | 11:36 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Same here. You have to pay to play...
R.K.
Old Mar 27, 2014 | 11:30 AM
AndreNY's Avatar
couple of Benzos
so once you have the Lowering module it automatically disables the Speed Sensitive Lowering ?
Old Mar 27, 2014 | 01:29 PM
radride's Avatar
Bingo. I've been saying this the whole time but no one ever listens. They go with the cheaper option; lowering links. I guess I'm not okay with having Home Depot suspension parts on my car.
R.K.
Old Mar 29, 2014 | 10:45 AM
Alex L's Avatar
CLK56TT (WIP), S65, RR 5.0 S/C
No. It gives the controls back to the car.
