Are rear adjustable camber arms needed at stock height???
Had mine lowered and done. Rides great and numbers are on the money.
Do it where they pull chassis. They know which bolts to adj. Good luck
There is only front and rear Toe adjustment OEM.
Problem with rear adjustable Camber arms is that they replace the upper factory arms and need to move top of tire outwards (thereby reducing all important clearance tire to outer fender) to reduce premature inner edge tire wear.
We saw the need to design/manufacture a precisely adjustable (single wrench) rear Camber kit to resolve this problem by adjusting inwards the lower arms. Then to combine extra Toe adjustment to compensate for this new Camber facility.
For the front you can purchase one position minimal adjustment crash bolts for Camber and Caster.
But again we saw the need "to fix it right the first time" with precisely adjustable kits with more than twice the adjustment range resolving premature edge wear, steering pull, improving traction. The result of curb knock damage, altering height, load carrying, fitting wide profile tires, etc.
K-MAC bushes at same time replace all the main wearing front and rear suspension bushings. No special tools required to fit.
Special promotion for month of May for USA/Canada MB World member is FedEx Air freight for $25 one kit or $35 front and rear kit (usually $70 and $85).
http://img204.imageshack.us/img204/47/002esa.jpg
But for a w215 CL coupe
know it eats tires but its for a show car
Extreme lowering by itself will give that look.
The K-MAC patented front and rear kits can then adjust tires either way - inwards reducing this excess negative Camber and inner edge tire wear or outwards further increasing this negative Camber.
It is important to realize when compared to the only alternative "industry standard" - slot bolts - K-MAC adjusters not only allow precise, fully adjustable fine tuning of Camber and Caster for the first time (not just these hit or miss one position bolts) but current K-MAC kits offer 4 times the adjustment range!
With ongoing precise adjustment being just a single wrench on car, no disassembly required each time, when wanting to alter height, tire width or for curb knock damage.
The race industry K-MAC front kits are used to increase negative Camber and track width to gain faster lap times. In the ongoing pursuit to lower times, get onto the front row of the grid, set pole position!
It is all about front end traction - allowing to go deeper into the corners and being able to hit corner apex's every time.
While K-MAC rear kits also besides Camber combine extra Toe adjustment to fine tune and get power to the ground/traction.
