CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
w215 CL65 window, mirror, button start
Old May 20, 2014 | 06:04 PM
bentleyboy's Avatar
CL65 AMG W216, Bentley Continetal R Le mans, Bentley Turbo RT, BMW 735 i, CL65 AMG w215
Quite a mixed bag suddenly developed after service by local stealers.
Driver's window sometimes doesn't close last 6 mm ; driver's mirror sometimes doesn't open fully ; gear selector start button sometimes doesn't do its stuff (just like a dead short)
Stealer wants it in for d/x on Star but also said I need to replace all the wiring in the driver's door.
This is apparently an unheard of fault ( s) .
Is window final close on vacuum pump ?
Is door mirror fully electric or also on vacuum pump ?
Is it likely a bad connection on start button ?
I would appreciate any knowledge regarding these annoying problems if any of you guys have some to offer.
Old May 21, 2014 | 05:44 AM
Mercedes22's Avatar
S500 LWB ( W221 ) - CL63 Biturbo ( W216 ) CL 55 Kompressor ( W215 Sold ) C43 AMG ( W202 Sold )
It is a very common problem with the wiring loom. I have had exactly the same problem.
Because the Drivers door has been opened on a regular basis over the years the wiring stretched. You need to expose the wiring loom and have the wires re-connected any competent auto-electrician could rectify the problem or if you have the expertise go for it.
Old May 25, 2014 | 08:03 AM
bentleyboy's Avatar
Thanks, I'll get into the driver's door tomorrow and examine the wiring harness. As a precaution, I left the battery on a trickle charge because I know from past experience that anything less than 12 volts causes all manner of faults to manifest themselves.
I'll post results.
Old Jun 8, 2014 | 10:49 AM
2Fast4U2C's Avatar
2003 Mercedes-Benz CL55 AMG
Hey, I'm having the same sort of problem. Did you have a chance to get it fixed? What was the outcome?
