CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
alignment question!!!!!
Old May 22, 2014 | 07:31 PM
biker349's Avatar
cl600
hi, just got my tires aligned at tire kingdom. after the alignment when i got home i checked the tire pressure and one front tire was at 35 lbs. and the other front tire was 46 lbs. called the shop and they said it doesn't make a difference on the alignment machine. are they correct and did the difference in tire pressure mess up the alignment. i was later told by a mechanic that i should only align the mercedes at the dealer because they have some special tools that are required for proper alignment. first did i get screwed at tire kingdom with an improper alignment. second is it true that i should only let a mercedes dealer align my car. p.s. i have a staggered set up.
Old May 22, 2014 | 07:58 PM
Dr Matt's Avatar
05 CL65
Pressures should be correct when aligning the car. How much will 11# throw it off I don't know, probablyh still be within specs.
