CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Are the rear control arms (up front) an easy swap?
Old Sep 10, 2014 | 12:16 PM
Grip Grip's Avatar
SLK55 AMG - Renntech Supercharged
The bushings on my rear control arms on the front of the car are shot (item 7 in the diagram). The parts arrived today, but I was wondering if it's as simple as it seems. The thing that sort of concerns me is lowering the arm and seeing the strut extend out. Hopefully I don't have to bother with the ABC system to swap the arms.
My method of attack is to support the car, and place a jack under the middle of the arm (item 7). Disconnect the balljoint (item 2), lower the jack under the arm until the bolt at item 8 can be removed.
Old Sep 10, 2014 | 01:03 PM
Dr Matt's Avatar
05 CL65
Sure looks simple enough, but I have done a lot of front end work. Never on a CL, however, i've never found anyto be difficult yet so I doubt these will be either. I can see no reason why it would involve the ABC system.
Old Sep 10, 2014 | 01:51 PM
Grip Grip's Avatar
I mentioned the ABC since the strut will still be pressurized. I don't know if it's allowed to fully extend once the control arm isn't holding it back.
Old Sep 10, 2014 | 04:52 PM
Dr Matt's Avatar
05 CL65
The rears were fine being unhooked when I put in my LSD so the fronts should be fine too.
Old Sep 10, 2014 | 05:06 PM
Grip Grip's Avatar
That's comforting to know. Thanks
Old Sep 10, 2014 | 08:27 PM
Grip Grip's Avatar
Does the lower control arm (#7) attach to the strut with hardware of any type? My control arm doesn't want to separate from the strut, and I suspect the female torx head I see at the bottom of the strut might be some type of retainer. Thanks.
UPDATE: The strut has two allen bolts that secure it to the control arm.
Old Sep 10, 2014 | 08:45 PM
Grip Grip's Avatar
Got it. Big thanks to Jason at BIP.
Old Sep 10, 2014 | 10:27 PM
Grip Grip's Avatar
I need a bigger hammer. Damn you to hell, ball-joints!
Old Sep 11, 2014 | 01:35 AM
calgarycl55amg's Avatar
2003 CL55 AMG
What were the symptoms that made you suspect the control arms?
Old Sep 11, 2014 | 02:53 PM
Grip Grip's Avatar
The only symptoms I suppose was loud squeaking when I drove over bumps. The reason for swapping them out was because they appeared worn out and dangerous.
Below are some photos of the old and new control arms. As you can see, the bushings were destroyed.
Are the rear control arms (up front) an easy swap?-20140911_112908_zpsip8vkhvb.jpg
Are the rear control arms (up front) an easy swap?-20140911_112914_zpsitaq3ik7.jpg
Are the rear control arms (up front) an easy swap?-20140911_133817_zpsnc8h2vtf.jpg
Here's the tool that made the job easy:
Are the rear control arms (up front) an easy swap?-20140911_134317_zpsnyejqxgr.jpg
Old Dec 17, 2015 | 10:38 PM
khutchinson22's Avatar
CL55
Im having difficulty getting the two allen bolts at the bottom of the strut loose. Is there anything special to them like reverse thread? Did you use air to remove them?
Old Dec 18, 2015 | 10:04 PM
fireman685's Avatar
2005 CL55
The biggest problem I had taking the control arms off were those damn ball joints. My bushings looked similar but my car wouldn't track straight over bumps and grooves.
I had no trouble disconnecting the strut. You might try some penetrant to help loosen them up.
Old Dec 19, 2015 | 01:26 AM
CL55
I ended up getting them off using heat and a manual impact driver. Took some doing for sure.
