Airborne, Well Maybe, ABC
Was driving a bit over the speed limit and came across a dip in the road. I got close to being airborne. I ruptured 2 of my accumulators, Both front units bit the dust. I had a spare new front, located on the driver side but am picking up the other Monday. No other ill effects beyond the two ruptured accumulators. Car drives harsher and has the typical 2 inches of sponginess when you compress the suspension.
That would not be a problem with an accumulator.
Assuming your description is accurate / and you have some mechanical background. These cars are complicated as most newer car's are but the suspension on these cars being much different.
Nnick
