CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Eurocharged ECU tune and pulley
Old Nov 19, 2014 | 12:39 PM
principledchiro's Avatar
2006 CL55 AMG
About to pull the trigger on a Eurocharged ECU tune and pulley. Aside from the ECU tune, is there much virtue to the smaller pulley? Will the additional blower heat worth the few additional ponies and trq.?
Old Nov 19, 2014 | 02:39 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you will like the additional power added heat is nothing the bigger heat exchanger or a stock cooling system cant handle.
Old Nov 19, 2014 | 04:38 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Do you have a new IC pump? If not that would be the first mod for that car, I would also do a HE and after that all the goodies. Either way you go you wont be unhappy but make sure that you have that IC PUMP
Old Nov 20, 2014 | 06:37 AM
tusabes's Avatar
Mercedes
Don't forget your coils are likely to burn out after a tune
Old Nov 20, 2014 | 10:27 AM
2006 CL55 AMG
Thanks all. Leaning to the Eurocharged Stage 1 or 2 packages: IC pump, pulley, ECU tune. And a Premier Performance belt wrap. Anyone here have Eurocharged tune, etc.?
Old Nov 20, 2014 | 11:51 AM
Dr Matt's Avatar
05 CL65
I have a EC ECU/TCU tune on my car.
Old Nov 20, 2014 | 12:35 PM
perfota's Avatar
2005 S55 AMG
Why would you burn out the coils? Aren't they just having that issue with the v12 coils?
I be interested to know why you made that comment, as I have the eurochared ECU tune installed at the moment. I also have the FSP 80mm sitting in the garage for the next project...Hum interesting. Did your coils failed? How many miles did you have on the car?
Please let us know
Old Nov 20, 2014 | 01:11 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Can you say more about this??? Coils on the 55??
We have around 5000 satisfied customers to date and offer one of the best warranties in the market!
Please let us know
Agreed...would be good to know that information as it would be the first I have heard of it.
Old Nov 20, 2014 | 02:28 PM
AndreNY's Avatar
couple of Benzos
I had a Eurocharged tune on my CL55 and I had nothing but issues due to my 82mm TB, if you have a stock TB you should be ok with their tune
Old Nov 20, 2014 | 03:33 PM
2006 CL55 AMG
ECU tune with pulley
A few days ago I spoke with a Eurocharged rep. He said they're still running the $399 ECU tune and $600 (?) if ECU tune and pulley. Some members mentioned first placing in a Johnson IC pump. This I have already planned to do as well as a belt wrap kit. Questions are: To achieve 550+ hp will a Eurocharged ECU tune and smaller pulley do the trick? What size blower pulley?
Old Nov 21, 2014 | 09:25 AM
Blkvip's Avatar
12' E559
you will in deff need cooling. friend actually did what you're posting about. dyno tune/pulley but no cooling. he needed it as it got fairly hot towards the top
Old Nov 23, 2014 | 03:06 PM
douggol's Avatar
2003 cl-55
Have the pulley and tune on my 2003 cl55.
Best part is increased pull at lower rpm . Makes the car much more responsive in each of the lower gears.
My best "change"was changing my supercharger oil.
The oil was gone and supercharger was probably closing in on failure as the kick in and shift out was becoming gradually rougher and more unpleasant.
With new oil it is like a new car with very smooth supercharger action.
And it takes 30 minutes and costs one can of oil.
Old Nov 24, 2014 | 11:53 AM
2006 CL55 AMG
Dr. Matt, IMO your already out of the box beastly TT V12 didn't need a tune, LOL
Old Nov 24, 2014 | 11:25 PM
Dr Matt's Avatar
05 CL65
Oh it needed the tune all right. Needs a bit more yet.
Old Nov 25, 2014 | 10:06 AM
2006 CL55 AMG
Pulley, I/C and Pump Upgrade
Doug, did you go with a smaller blower pulley or larger crank pulley? Was the upgraded I/C and pump added too? What oil used to refill blower? Thx
Old Nov 25, 2014 | 07:31 PM
douggol's Avatar
2003 cl-55
I did supercharger pulley exchange to smaller. No crank change.
pump upgrade done but I have had no problems with supercharger cut out even before replacement.
Oil for the supercharger is Mobil jet oil ll.
Doug G
Old Nov 27, 2014 | 01:08 PM
2006 CL55 AMG
THX AMG brothers. Enjoy turkey day
