CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Help with car hesitation mystery
Old Dec 9, 2014 | 09:49 AM
Afr00t's Avatar
'03 CL55 AMG & '09 SL63 AMG
Hello guys, I've been trying to figure out whats wrong with my 2003 CL55 for the longest time and need help
Car jerks when i gun it from stop. Or it will lose immense power for couple seconds after shifting or until it pickes rpms back up. It also barely goes when i hit the gas while the car is on high gear and low speed (ex: driving 45mph on fifth gear then hitting the gas pedal). *it seems to jerk only when theres load on the car.*
The car doesn't have any issues when i hit the throttle on neutral or when i hit the gas when the rpm is readily high. Sometimes if i want to gun it i slowly climb up the rpm then hit it when the rpm is high.
The car does hesitate alot worse when it's on very low rpm (800-1500rpm)
Things i did in hope to solving the issue:
Changed fuel filter
Cleaned throttle body
Mixed injector cleaning additives to the gas
Checked airfilters
Deleted all 4 catalytic converters
Deleted resonator
Changed supercharger to fixed pulley w/ ecu tune
Changed ic pump to bosch 010
Any help would be appreciated, ive been stuck with this issue for months now
Old Dec 9, 2014 | 10:29 AM
SL55_Forever's Avatar
3-pointed star
When was the last time you changed your intercooler pump?
Old Dec 9, 2014 | 10:33 AM
Afr00t's Avatar
Had the car for about a year and I havent. Not sure if the previous owner did. Will the IC pump cause such symptoms?
Old Dec 9, 2014 | 10:37 AM
principledchiro's Avatar
2006 CL55 AMG
Transmission issue? Torque converter?
Old Dec 9, 2014 | 12:48 PM
Afr00t's Avatar
Is there a way i can diagnose and figure out if that is the issue?
Old Dec 9, 2014 | 04:42 PM
2006 CL55 AMG
Failing torque converter will illicit "surging" behavior. Begin with SL55 forever's suggestion of inter cooler pump. There's no CEL (check engine light) if fails but the ECU will cut power via spark and fuel.
Old Dec 15, 2014 | 09:38 PM
CL600CK60V12's Avatar
2008 S65 AMG, 2005 SL65 AMG, 2005 Porsche Carrera, 2011 Shelby GT500, 2001 Acura CL Type S
ESP
I just went through a lengthy and annoying debugging of the ESP Malfunction. Try getting another ESP module (from ebay - you can get it for $100 or so). If that does not help, it is possible that throttle body actuator is going bad or your accelerator pedal (and sensor which is part of the pedal).
A pain in the neck to debug. Hope this helps.
Old Dec 16, 2014 | 10:19 PM
JPhamily's Avatar
Mercedes CL55
I have the same problem... Im guessing its the spark plugs and spark plug wires, if not that then the coils?
Old Dec 16, 2014 | 11:49 PM
Afr00t's Avatar
Wouldn't all of these throw a CEL? I don't have a CEL for those possible malfunctions
Old Dec 16, 2014 | 11:51 PM
Afr00t's Avatar
Is there a way you can film the symptoms or briefly explain it? I believe there are many things could cause similar symptoms. I'm gonna try and change all the spark plugs and check wires for resistence, not sure how to check the coils though.
Old Dec 17, 2014 | 06:08 PM
JPhamily's Avatar
Mercedes CL55
In my case, the car jerks only after I have been driving for awhile. I also noticed it happens when I drive hard, like after I just floored the car. It almost seems like the car is ether not getting fuel or its about to shut off. Scary thought because it happens on the freeway... Im hoping it's nothing major. I hope you get your problem solved.
Old Dec 18, 2014 | 08:01 AM
Afr00t's Avatar
Have you checked your IC pump? Your issue sounds like sounds like your IC pump is shot. Look into that
Old Dec 20, 2014 | 04:14 PM
douggol's Avatar
2003 cl-55
Have you changed your supercharger belt recently?
Belt slip might cause this. A new belt helps cut in and out smoothness.
Intercooler pump is my other idea.
Doug. G
Old Dec 20, 2014 | 09:24 PM
JPhamily's Avatar
Mercedes CL55
Doug. G
I havent checked that out yet but I don't think thats the problem. I feel like it can be the throttle body or the fuel injectors being dirty?
Old Dec 22, 2014 | 02:18 PM
Afr00t's Avatar
Cleaning the throttlebody is a relatively simple thing to do so i would definitely start with it. Even though i don't think a dirty throttlebody could cause such an issue, maybe if ur car is idling rough but i do t think a dirty throttle body would slow down the car on an open throttle. And if u think it's the fuel injectors u could try those fuel additives they sell at every gas station. But in my opinion your issue sounds like it's a bad IC pump. Does ur car run fine when it's cold and get worse when it heats up or drive it for a while?
Old Dec 22, 2014 | 02:19 PM
Afr00t's Avatar
I'm now looking into the supercharger. Suspecting it's either the sc belt like you said, the belt tensioner went bad, or the SC clutch going bad.
Doug. G
Old Dec 22, 2014 | 11:01 PM
Beast55AMG's Avatar
2005 E55 AMG, 2006 SL65 AMG
I had a similar problem with my 2005 E55 and it turned out to be the fuel pump (I had fuel leaking into the wires and it corroded them). It would drive fine but stutter when I floored it. You could try checking the fuel pressure (you can rent a fuel pressure gauge from auto parts store usually). You could also try doing a visual inspection of the fuel pump and wires. When I plugged my car into the STAR diagnostic system it also told me I had an issue with the fuel pump. Hope this helps.
Old Dec 23, 2014 | 01:11 AM
JPhamily's Avatar
Mercedes CL55
Now that you pointed that out about the car driving fine when cold and worse when it heats up, I think it might just be the ic pump because I can floor the gas pedal when driving the car for only 10-20 minutes but after driving the car for awhile and flooring it, it stutters. It almost feels like the engine shuts off and turns back on… My car is almost at 160k, its at the point where everything needs to be replaced.
Old Dec 23, 2014 | 01:14 AM
JPhamily's Avatar
Mercedes CL55
I actually just replaced my fuel filter not too long ago but didn't check to see if theres any visible problems with the pump. I will have a friend plug the car into star and see whats the problem. Thank you for your help.
Old Dec 24, 2014 | 11:13 AM
Afr00t's Avatar
Do you know how much pressure the gauge should read for the fuel pump to be in regular working condition? Did your fuel pump ever throw you a CEL code? I'm going to also look into replacing my fuel pump but I want to make sure it is whats causing the problem before i waste money replacing it.
Old Dec 29, 2014 | 03:19 AM
JPhamily's Avatar
Mercedes CL55
If the fuel pump is bad, the car wouldn't be running at all wouldn't it?
Old Dec 29, 2014 | 09:43 AM
fireman685's Avatar
2005 CL55
I had similar issues. I replaced the IC pump with a new Bosch one. My car has since come alive and I have the infamous chirp of the SC kicking in now. The pump is cheap and relatively easy to replace. If it's the original pump you need to replace it anyway as it is most likely dead weight.
Old Jan 5, 2015 | 12:38 PM
Afr00t's Avatar
I actually replaced the pump to the new BOSCH 010 and it didnt solve the problem. I just purchased a smaller blower pulley with an ECU tune from Eurocharge and going to see if changing the pulley (which will eliminate the clutch) will solve the problem. If not, I'm going to look into the Torque Converter and Fuel pump
Old Jan 5, 2015 | 01:24 PM
Jbobiccus's Avatar
Still looking
Really sounds like the typical intercooler pump issue. Eurocharged sells them for $150.
Old Jan 12, 2015 | 11:20 PM
driveability's Avatar
Cl65 AMG
Classic secondary ign problem. Week coil (coils ? ) plug wire or cracked / corroded spark plug. If you can mix up some salty water and spray it all over the above parts. Drive it and see if it changes or just gets worse. Cold engine needs more KV as well as under load and more when engine is lugging along.
