CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Multiple Sudden Malfunctions! Help!
Old Dec 29, 2014 | 02:33 PM
khutchinson22's Avatar
CL55
Driving into work this morning all the power is gone. It's like The supercharger is gone. I get off the highway and I get ESP malfunction the about a mile later ABC malfunction. I ran codes and all that comes up is Secondary Air Injection.
Any ideas?
Old Dec 29, 2014 | 02:47 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
check all the drive belts.
seems like you have an idler pulley failure.
Old Dec 29, 2014 | 03:47 PM
CL55
That was exactly it. Somehow the belt came off.
Old Dec 29, 2014 | 04:46 PM
shardul's Avatar
time to replace them with after market ones
Old Jan 1, 2015 | 01:35 PM
CL55
There is a little bit of a wobble in my supercharger pulley. Is this something I should be concerned about? I've tried tightening the others. One seems to have a stripped bolt (not the tensioner or harmonic.....I'm assuming the ABC???) The belt is jumping off frequently and I hear a squeak.
Old Jan 6, 2015 | 01:00 AM
CL55
Solved!
The idler pulley bolt hole on the front engine cover had been stripped out causing the SC belt to be thrown off. Replaced the bolt with a longer one that allowed me to put a nut on the other end to tighten it back down. Worked perfect.
