CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Annoying clunk in the trunk….
Old Jan 13, 2015 | 09:37 PM
JPhamily's Avatar
Mercedes CL55
I have this stupid annoying clunk in my trunk whenever I go over bumps. It sounds like something is hitting the tube in the trunk. I took everything out of my trunk and it still clunks when driving.. I have no idea what it is, anyone have any clues to what it might be?
Old Jan 14, 2015 | 09:19 AM
Dr Matt's Avatar
05 CL65
Strut top bushings? Jack up the car and use a pry bar to try and lift the rear tire to check it for play.
Old Jan 14, 2015 | 03:08 PM
awiner's Avatar
2003 CL55 AMG
Also check the rear subframe bushings. They often collapse after time and need replacement.
Old Jan 16, 2015 | 07:20 PM
khutchinson22's Avatar
CL55
I had this problem in the front on my 03 CLK500 and it was the sway linkage. Easy fix.
Old Jan 4, 2016 | 02:18 PM
CL55
I am having this issue now as well. Seems to be coming from the passenger rear. Happens when going less than 45mph (maybe slower). I looked last time it was up on the lift and didn't notice anything loose but there is definitely something going on in there.
Old Jan 9, 2016 | 07:07 PM
gslse21b's Avatar
2005 CL65 ,2010 GL550
Don't forget about the fuel tank baffle coming loose
Old Jun 29, 2017 | 06:27 AM
principledchiro's Avatar
2006 CL55 AMG
Bump. Right rear clunks are almost certainly rear subframe bushings. The 500+ lb/ft torque compresses and tractions them with much veracity.
