CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Speedriven Downpipes for 2007-13 CL65
Old Mar 10, 2015 | 02:32 PM
Speedriven1's Avatar
Speedriven
Made from high-quality stainless steel and designed to be direct replacements for the factory components, these new, lightweight, high-flow performance downpipes from Speedriven deliver serious performance gains without compromising the sound quality of your V12 Mercedes.
BUY IT ONCE
Speedriven developed these downpipes to provide a significantly more exhaust flow than the factory units. This improved flow delivers a noticeable increase in horsepower, torque, and throttle response across the RPM range- but there’s more to these downpipes than a simple, “better than stock” upgrade. Speedriven developed these downpipes to provide sufficient airflow for everything from stock turbo builds to billet-wheel turbos to our most powerful, 1000+ HP “big turbo” packages.
In other words, you can buy the Speedriven high-flow performance downpipes for your stock Mercedes V12, and enjoy them for the life of the car- whether that means leaving it stock, or building up into a record-running track weapon.
Speedriven’s stainless steel downpipes are available now for W221 and W216 Mercedes-Benz 600 biturbo V12 and 65 series AMG models, and are available now with or without cats for $2000 or $1400, respectively.
Speedriven Downpipes for W221 and W216.
Old Mar 11, 2015 | 07:03 PM
stealth09's Avatar
CL600
What diameter is the downpipe? Will I throw a code without the cat?
Old Mar 12, 2015 | 10:41 AM
Speedriven
Is your car tuned? In most cases, if your ECU has been flashed there will be no CEL, but you may throw one on a stock car. We have an option with sport cats that is still significantly less restrictive than stock and which should be fine with or without a tune.
Old Mar 12, 2015 | 02:07 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
They look good Bump for a nice set of pipes
Old Mar 12, 2015 | 03:40 PM
stealth09's Avatar
CL600
No tune on mine, don't really want cats on it either. Is this 3" or less?
Old Mar 12, 2015 | 04:29 PM
Speedriven
They are 3" pipes.
Old Mar 30, 2015 | 04:22 PM
Speedriven
** NOTE: these fit the 600s, as well.
Old Oct 6, 2015 | 10:44 PM
beauphus's Avatar
CLS55 & CL CK60
are these still available?
Old Oct 7, 2015 | 10:47 AM
Speedriven
Yes. I have a pair in-stock right now.
Old Dec 27, 2021 | 03:35 PM
jy600's Avatar
07 Mercedes CL600
BUY IT ONCE
Hi Do you have another downpipe for a 07 CL600?
Old Feb 4, 2023 | 09:17 PM
WIN ER's Avatar
2007 S65 AMG (W221)
Is it actually a live thread or already dead?
