CL55 amg tune and pully
Actually I have a cl55 amg 2003 and it is so cleaned and in good condition.
I am planning to do a tune for it and change the stock supercharged pully to a custom one and i have no idea about the suitable tune for my car. And i am wondering if it is effect on the car engine or gear i mean is the tune bad for the car at all ?
Anyone have an idea about the cl55 tune and which is suitable for the car stage 1 or 2 or 3 ..... etc ? and does the tune bad for the engine and gear and the whole condition of the car ?
*Also please i need your guaidance and help about the custom supercharger pully if it is bad for the engine and supercharger condition or not ?
thanks a lot
best wishes
as for ecu tuning, it all depends which tuner you go with...
if your motor is stock, then i suggest you to start with large crank pulley and tune first...
why bother with "custom" sc pulley???
thanks a lot for your help
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Many people suggest to me to change the sc pully and tune it and I am planning for that.
what about the Exhaust system also ?
Best wishes
Ahmad
