CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Re-set tire pressure monitoring
Old May 28, 2015 | 04:39 PM
principledchiro's Avatar
2006 CL55 AMG
Four months ago all wheels received new wheel tire pressure monitors with valves. A few weeks ago the display has one problem message: TPM system inactive, drive to work shop.
I've read here those who've pulled and reinstalled fuse #70 at the rear passenger fuse block. With the engine on the fuse was puled then reinstalled...same message pops up after some driving.
Any ideas...suggestions?
Old May 28, 2015 | 04:55 PM
Dr Matt's Avatar
05 CL65
My aftermarket TPMS don't work either. You can reset them on the dash with the steering wheel controls, but I haven't messed with mine in a while so I do not recall exactly where in the menu to find the control for it. I'll try and look tonight and post up where to find the on/off for the TPMS's if no one beats me to posting it up. Fwiw, when I bolt my winter tires on the system recognizes them and shows me the pressures automatically without having to do a reset, but my new wheels and aftermarket sensors do not work at all.
Old May 28, 2015 | 05:18 PM
2006 CL55 AMG
Doc, several times performed steering wheel reset the TPMS, it'll reset but go inactive short time later.
Old May 29, 2015 | 01:57 PM
biker349's Avatar
cl600
had this problem when i bought after market sensors on amazon. replaced with oem from tire rack. problem solved. are your sensors after market?
